Home › Forum › Ask A Member › Spark plug
  • #283850
    benji41
      What is the correct spark plug for 1958 Evinrude 10 HP
      Jim Benjamin
      #283853
        J6C
        #284020
          For some reason, starting in 1957, OMC started  recommending the slightly colder  J4J for their motors. Why, I don’t know. Maybe because two-stroke oils were improving and burning cleaner or  people were pushing their motors harder.
          The actual use and condition of the motor will help determine which ones to use. Cold water use and tired, lower compression motors will probably like a hotter plug while motors pushed hard as in water skiing or steady full throttle operation will benefit more from a colder plug.
          As noted, the old J6J’s cross over to modern J6C’s or NGK B6S while the J4J’s cross to J4C or NGK B8S.
          57-58-Johnson-Plugs
          #284044
            Jim,
            Look at the motor prices!!!
            #284046
            retiredoz
              OMC must not have told Champion about the change.  My ’59 Champion cat still lists J6J for the QD series.
              #284048
              JOSEPH BRINCAT
                I run J6 in my 1957 35hp Lark and they run fine. Now, consider if you plan on running wide open much of the time, maybe go to the colder J4’s
