Home › Forum › Ask A Member › Spark plug? -1937 Muncie Neptune O B12A
  • #274486
      Anyone have a spark plug chart showing the correct 18mm spark plug
      for the 2 HP, 1937 Muncie Neptune O B12A?
      Could not find it on any of my data, nor online.
      Thanks.
      MIKE SIMS
        From notes I have I can not see an OB12A, only an OB12. Earliest ’42 chart says an 6M, ’55 chart says 6MJ and my ’65 chart says K-15J
        #274497
          Old Outboard Book says – 6M
          Old Outboard Book cross over chart says – K15J.
          Internet search –
          • Autolite 386
          • Champion D14
          • Champion D14013
          • Motorcraft BTS8F4
          • NGK 1010
          • NGK 2910
          • NGK A-6
          • NGK AB-6
          • NGK AB6
          • NGK stk 2910
          #274498
            Thank you both. I always forget about the “Old Outboard Book”,
            that was sitting two feet away, underneath some papers!
            I put a D16 in the one I fired up yesterday. Can’t remember
            if that’s Hotter or Colder than the recommended D14,
            but I have a chart for that!
              Just looking at the gas cap you made for the 36.
              Pretty cool!!!
              #274852
                Thanks Tubs. I was amazed it actually fit and
                screwed on okay. Internal threading in a blind
                hole is a challenge for me!
                Thanks for the spark plug data.
                I found some D-14’s so the little Neptunes
                should be “good to go”.
                Pretty cool!!!
