Home › Forum › Ask A Member › Spaghetti seal for ‘67 Evinrude Fastwin ?
- This topic has 13 replies, 7 voices, and was last updated 3 years, 11 months ago by
rmhxruss.
December 1, 2022 at 3:29 am #269564
Hello everyone,
First post and looking forward to getting to know this forum. I recently picked up a 67 Fastwin and have started disassembling it to see what I have. So far so good – compression is 110/108 and the ignition and fuel seem to be completely rebuilt (as promised by the PO). The lower unit is apart now and the gears/other bits appear to be in pretty good shape. I’ve ordered a new water pump as well as seals for all the shafts from Crowley. First question is whether there are more highly recommended suppliers than Crowley ? Second question is where to order the spaghetti seal from since they don’t offer it. I see them on Amazon but would prefer a known-good rubber compound from a reputable supplier. Also, I’m planning to coat this seal as well as all bolts with permatex aviation sealer since the OMC version does not seem to be available right now. Any input appreciated. Thanks
December 1, 2022 at 6:58 am #269571vintgaeoutboard.com sells GC seal kits …give them a call they may sell just spaghetti seal if you have the rest
I purchased it by the foot locally years ago … it comes in diff. diameters and compound
try bearing/seal shops
December 1, 2022 at 7:04 am #269572Also someone recently mentioned Laings Outboard as having the seal kits and comes with the spaghetti seal.
December 1, 2022 at 9:04 am #269575Thanks to you both. Wish I’d found VO and Laings (and a few other sites listed in the resource section of this site) before I ordered piece-meal from Crowley. Will give them a try – much appreciated. Any feedback on installing the seal dry vs with the aviation goop ? I also plan to use the same loctite in each of the bolt holes since they are inboard of the spaghetti seal.
December 1, 2022 at 9:14 am #269576A quick follow up…. Just talked to a very nice guy at Laings who did agree to sell just the spaghetti seal to me. I was impressed with them and will be calling them next time I need some parts. Thanks for the tip.
December 1, 2022 at 9:33 am #269578You’ve already found what you needed but for future reference, here’s some other sources. You can buy the spaghetti seal by the foot from McMaster Carr, 3/32″ width, their product number 9407K11. Here’s the link:
https://www.mcmaster.com/buna-n-rubber-seals/oil-resistant-buna-n-o-ring-cord-stock-7/
You can find a complete gearcase seal kit listing on Marine Engine. Once you get the correct seal kit number from the list, you can buy from them or check other sources. It pays to shop around on some of these kits. Here’s the link to their listing:
Marine Engine also has similar listings for water pump kits, carburetor kits, tune-up kits, etc. Welcome to the forum!
This reply was modified 3 years, 11 months ago by
Bob Wight.
December 2, 2022 at 4:14 pm #269614Thanks Bob. I appreciate it.
December 3, 2022 at 9:24 pm #269649Hey iron horse I have the same question. Dry or aviation goop? Welcome to the forum. The guys on here are great!
December 4, 2022 at 7:50 am #269651see book…
December 4, 2022 at 8:19 am #269655Thanks Crosbyman. Do I understand correctly that along with membership comes the ability to view the entire service manual ? That is definitely a value.
