Home › Forum › Ask A Member › silly but need to know
  • #205288
      the main bolt (PART #1) on the handle grip of my 1959 5.5 hp will not go all the way in ????? about 1/4 inch sticks out
      shift rod threads are ok bolt threads perfectly good but when I line up the shift rod in the handle the bolt goes in fine… lines up perfectly threads in smooth but all of a sudden the last 1/4 inch won’t go in
      I see no obstructions … yet the bolt will not insert flush in the handle 🙁
      if this keeps up i’ll retap the shift rod and use a shorter bolt to secure the handle….which I don’t like because it was in there at the start when I took the cracked shifter handle of the motor to fix it
      #205298
        That screw is a special thread not found in your everyday tap and die set. 12-28 if I remember correctly and I had to order mine from a tool company.
        #205300
        CHUCK
          Crosbyman! That PDF is cool! How do you make a PDF from a scrollable web-page like that? A browser plug-in of some sort?
          #205301
            all I did was go on marine.com and do a print of each sub section (ex: carb, gearcase, cowl, tank etc…) and printed the section (CTL P)
            when you print something Windows offers to send the print to a known printer and /or………… a PDF file
            select PDf and away it goes
            I store the file like any other jpg, pdf etc.…
            now what about my silly 12/28 bolt ????
            #205304
              Those rods are very easy to cross-thread. Never mind how I know. You might get lucky and run the screw in from the opposite side to straighten the threads,, then put it together with great care not to cross-thread it again.
              I would have guessed it is a 12-24 screw, but dunno just off hand.
              #205312
                12/28 measured it threads are not damaged and fit fine if I do not install the handle ??
                the bolt screws all the way in the rod’s threads but when I line up the hole in the handle with the hole in the rod the bolts only threads until .25 inches do not go in ?? like I said it is silly because I can poke a stick all the way in longer than the bolt yet I hit no obstructions but the blot won’t go all the way ???
                patience brings joy i’ll try tonight with a new mindset
                #205321
                  ok getting mad here….
                  anybody know how long that silly bolt is… or needs to be … my hacksaw and tap set are waiting 🙁
                  • This reply was modified 6 years, 5 months ago by JACQUES.
                  #205327
                    Happen to have a tiller apart right now. Screw #305001, same as yours and mine measures out 7/8″ total thread length.
                    1982 Evinrude 25hp
                    #205383
                      ok i’ll check it out a.m. first thing thanks
                      #205387
                        Took me awhile to come up to speed on this as “shift handle” kept being referenced. So you are replacing a broken THROTTLE handle? That’s the only new part? Is it the same part as the one it is replacing? Why do I seem to remember that some of those screws are longer than others, because some go all the way through the throttle shaft into the other side of the handle, whereas others only just are long enough to go into the shaft itself?
                        • This reply was modified 6 years, 5 months ago by billw.
