Home › Forum › Ask A Member › Silicon grease packet???
- This topic has 9 replies, 6 voices, and was last updated 3 years, 3 months ago by
jeff-register.
July 26, 2023 at 5:21 pm #278526
What is the small silicon grease packet that comes with a new set of points/condenser used for???
July 26, 2023 at 5:29 pm #278527Should also be a felt pad to lubricate the cam. The packet contains the lubricant for the pad.
July 27, 2023 at 8:16 am #278529That makes sense. The pad seemed to already have grease in it but it makes sense to add some. Is this a maintenance issue where you pull the flywheel occasionally and add some grease to the pad?
July 27, 2023 at 9:43 am #278531If the pad is already lubricated, don’t put more lubricant on it. Save the capsule for later. I wouldn’t remove the flywheel very often just to add lubricant. You may have a port on top of the flywheel to access the points. You may be able to add lubricant through that port. I just add a few drops of 3-in-1 oil to the felt pad whenever I’m in there. Don’t over -lubricate.
July 27, 2023 at 4:20 pm #278546The felt pad is for oil. The grease would be placed on the back side of the fiber block of the points that runs on the cam. As it wears grease is deposited on the cam lubricating and extending the life of the fiber block. As you have a felt pad you can discard the grease. Tubs
July 27, 2023 at 5:01 pm #278548you can add some on the point pivot shaft
July 27, 2023 at 5:02 pm #278549I heard that you are supposed to swallow that pill 1/2 hour before replacing the points. That will dilate your eyeballs so you can set the points gap without a feeler gauge.
July 27, 2023 at 5:38 pm #278551FR… today some would take you to your word and swallow it…and still complain the timing was off !! then sue ! funny nonetheless !
July 27, 2023 at 5:46 pm #278552I heard that you are supposed to swallow that pill 1/2 hour before replacing the points. That will dilate your eyeballs so you can set the points gap without a feeler gauge.
It’s faster acting if inserted at the other end. Tubs
July 27, 2023 at 10:29 pm #278573Ive washed the pad with dishsoap to get it clean & relube, but I like Tubs & Franks suggestions better.
