Home › Forum › Ask A Member › Sierra Low Unit Seal Kit Charts?
- This topic has 6 replies, 3 voices, and was last updated 2 years, 6 months ago by
Buccaneer.
May 5, 2024 at 9:23 am #287603
Anyone have a Sierra lower unit seal kit chart / list for the 50’s & 60’s OMC
outboards? The only one I have is for much newer units.
Thanks.Prepare to be boarded!
May 5, 2024 at 3:44 pm #287613Buc – here’s one on Marine Engine that goes back into the 50s and 60s.
"Every time you remove a broken or seized bolt an angel gets his wings."May 5, 2024 at 5:44 pm #287617Thanks Bob. I thought ME might have had info., but I couldn’t find any link
to it on their homepage. Bookmarked now.
Strangely, they don’t list a seal kit for a 1956 QD 10 hp that I may be
working on for my cousin.Prepare to be boarded!
May 5, 2024 at 7:42 pm #287629Nope, that has that prop shaft seal that Sierra doesn’t have available
May 5, 2024 at 9:27 pm #287640Nope, that has that prop shaft seal that Sierra doesn’t have available
Also OMC’s version is N/A anymore either.
Looks like the best bet is a CR 6280Inches (IN) Millimeters (MM) Shaft 0.625 15.88 Bore 1.250 31.75 Width 0.313 Prepare to be boarded!
May 5, 2024 at 10:05 pm #287641National Seals #471264 also works for that size shaft and housing bore, but is 0.250 in width and their #470018 seal is 0.375 in width. The CR seal you found is likely the closest fit to original.
"Every time you remove a broken or seized bolt an angel gets his wings."May 6, 2024 at 9:17 am #287647National Seals #471264 also works for that size shaft and housing bore, but is 0.250 in width and their #470018 seal is 0.375 in width. The CR seal you found is likely the closest fit to original.
Thanks Bob, I ordered the CR 6280 last night.
