Home › Forum › Ask A Member › Should I balance the rotating assembly?
  • #262833
    Mossman747
      Hello all,
      I am rebuilding a pair of 1960 Evinrude Lark IIs on my 18’ Lyman.  One powerhead has a bad crank and I am replacing it with a NOS crank and good used flywheel.  Should I have the crank and flywheel balanced as an assembly?  I am also considering balancing the piston/rod assemblies for a fully balanced rotating assembly.  Would this be worthwhile or would it not make an appreciable difference in a 2 stroke motor?
      regards,
      Mike
      #262836
        Good question.  Some of those 40’s were downright scary with vibration.  Once upon a time, back in “The Day” I attempted to balance one.  Maybe I didn’t know what I was doing (true), but the result turned out as bad or worse than the original.  Go for it if you want, but I wasted my time.
        BTW, do you know the 1960 40hps had a problem with breaking crankshafts?  Obviously, they didn’t all break because thousands of them survived.
        #262839
        Mossman747
          I’ve heard that about breaking cranks. The crank I’m replacing was actually ok except for the fact that a previous owner damaged the taper then aggressively smoothed it out with a file causing the flywheel to have about .050” of run out which caused  enough vibration to completely wear out all of the ignition and throttle linkage.
