Home › Forum › Ask A Member › shift rod bushing without removing the prop shaft?1990 Johnson 25 hp J25RESB
  • #190271
    outboardnut
      Is there a way to remove the shift rod bushing without removing the prop shaft? I am trying to avoid messing with the detent balls. (I don’t have the special tool to reinstall the detent balls)
      http://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1990&hp=25&model=J25RESB&manufacturer=Johnson&section=Gearcase
      gear-case-pic
      #190322
      outboardnut
        I just got a call from a fellow member and he told me to tap the brass shift rod bushing (5/16 tap) Then use 5/16 threaded rod to pull out.This way I would not have to mess with detent balls and still be able replace the seals and o-rings
        #190333
        durco
          Thanks for sharing that information.
          #190389
          donsmarine
            i think you can use the clutch dog to install detent balls and spring, make sure you look inside dog shaft hole for proper align of groove for balls
            #190638
            johnyrude200
              You can tap the brass busing and then remove with a puller you make yourself (simple to do). I dont recommend this on one of these gearcases but it could probably be done.
              You CANNOT install the clutch dog detent ballbearings on a 1990 3-lug clutch without the installer tool. On the 2-lug clutch dogs (pre 1981-2ish), you can.
              Even with the tool, it is very frustrating. My first one took me literally 3 hours. Ive got it down to 10-15 mins now. There’s only 1 way to get it back together and everything is coated down with gearlube if you catch my drift….
              #190652
              outboardnut
                I did not see your post until now.
                I made puller and got out the shift rod bushing
                that is far as I got today
                Why don’t you recommend doing it this way?
