Home › Forum › Ask A Member › Shear Pins and Shock Absorbers
  • #1858
    drifter
      Over the last several years I’ve accumulated several broken or slipping shock absorbers used in the 50’s and 60’s OMC smaller horsepower outboards.
      So, to salvage them for use I TIG welded them after ensuring they were the proper length.
      My question is ….. Using these welded shock absorbers, what is better – a brass drive pin or aluminum drive pin? All of the outboards I’m collecting and using are 10hp or smaller.
      Also, is there a source for the rubber tail cone (p/n 0303365) used on these outboards? New or used?
      As always, thanks for the help and making this a fun hobby.
      Drifter
      #18906
      Steve D
        I’ve bought new ones from Peter at nymarine.ca
        http://www.nymarine.ca/propnuts.htm
        #18907
        david-bartlett
          As far as brass or aluminum pins go, I think either would be ok, but I would use with brass for corrosion reasons.
          #18911
            Depending on alloy used, brass is approximately 12% stronger in terms of shear strength. Unless you enjoy changing broken shear pins, I would choose the brass. Just my opinion.
