Home › Forum › Ask A Member › Severe Back Fire
- This topic has 13 replies, 9 voices, and was last updated 9 years, 4 months ago by
garry-in-michigan.
June 12, 2017 at 12:03 pm #7308
Good Morning, First let me thank the club for allowing me to join in the forum. Now right to it! I purchased a 1954 Lyman that came with a 1956 Johnson RD-18 30hp motor. Over the winter I replaced, with all new, the points, condensers, wires, plugs, coils, everything ignition related. I went to fire it up this weekend and the only thing that happened was a backfire so intense that it blew the top of the starter motor off, from this I mean, it broke off the cotter pin, and sent the bendex flying. I pulled the fly wheel off on rechecked my point gap, and wire connections, same results. Do you have any thoughts on what I did wrong or what could be causing this?
Thanks, Tom
June 12, 2017 at 12:11 pm #59520Are the spark plug wires on the correct plugs?
Do you have even compression, and therefore no
pistons or cylinder walls that are trashed?Prepare to be boarded!
June 12, 2017 at 1:17 pm #59524Thanks, Yes first thing I did before I even began was to check compression, all good there. I will check to make sure the plug wires are on the correct plugs, then give it another go.
Thanks Again, Tom
June 12, 2017 at 1:37 pm #59525For reference – the TOP cylinder is fired by the FRONT coil. When looking down at the mag plate, the coil closest to you is wired to the points & condenser to the coil’s right/counterclockwise from the coil.
June 12, 2017 at 1:56 pm #59529Maybe the flywheel key is bent or sheared? As you probably know, the shaft must be clean and dry. I found this out after many a backfire.
June 12, 2017 at 2:33 pm #59536Easy way to check any 2 cylinder motor, Plugs out turn over the motor by the top nut watch a set of points. When they open stick a screwdriver in the plug holes.
Piston closest to the top gets that set of points.
June 12, 2017 at 2:44 pm #59538Thanks, I know for a fact that the shaft is not dry, it’s clean.. I pull the fly wheel again and recheck everything again. This is all good stuff!
Thanks again, Tom
June 13, 2017 at 2:16 pm #59605Sorry, Cook. The shaft and flywheel must be clean and dry… No lubricant … or it will shear off the key (in my experience)
June 13, 2017 at 11:04 pm #59629Are you sure the plug wires are on the correct plugs? Just swap them around and try it, will only take a few minutes
June 14, 2017 at 12:50 am #59639Is the magneto properly synced with the carb?
