Home › Forum › Ask A Member › setting points on lark
  • #2145
    mgsolakis
      When setting the points do I set them open to 0.020 where it says top and has an arrow? That does not look like the fattest point of the shaft.
      #21156
        The "top" is to show which side of the cam faces up.
        #21157
        mgsolakis
          So means nothing and I should set them at the widest point. On some motors I’ve set points on there is a mark on the flywheel. This one has no mark or perhaps it is worn off.
          #21161
            The mark on the flywheel is where they just start to open, not their widest gap. SOME cams have a "set" mark at the high spot, most do not. Easy way is align the points’ rubbing block with the keyway. Or do it right and use a timing fixture. Heh.
            #21186
            mgsolakis
              Thanks
