Home › Forum › Ask A Member › Sears waterwitch.
  • #325432
    shakespeare
      I bought a sears Waterwitch I cleaned the points and got spark and could put gas in the cylinder and it would fire up. I cleaned the carburetor yesterday and replaced the intake gasket. Now I can’t get it to fire up even if  I put gas in the cylinder. It has spark, gas, compression. Any suggestions would be appreciated. Thanks!
      #325462
        Could just be too much gas in the cylinder and its flooded. Take the sparkplug back out and pull the motor over 6 or 8 times to get some air in the cylinder. Put the plug back in, be sure the timing is advanced all the way, and try it again. You should know these motors have a bad reputation and deserve it. While some do run ok, not starting isn’t that unusual with these. I have one that starts easily but runs like crap. The other use to run but now it won’t run at all. They are also fragile. Parts, like the tiller, can easily be broken.
