Home › Forum › Ask A Member › Sears Motor Information
- This topic has 6 replies, 3 voices, and was last updated 6 years, 4 months ago by
bill-m.
June 17, 2020 at 3:31 pm #205994
Hi all, I just received the 1964 Sears 3.5 hp motor I bought a couple months ago. It is made by McCulloch. The motor is complete except for the Pin that adjusts the angle of the motor. I have taken the gas tank off so I can remove the rust inside. I am getting ready to pull the flywheel so I can inspect the ignition parts. So far at this point I have no guide to help me. I am in need of an owner’s manual, parts list and possibly a service manual. If anyone has any or all of these and could post them or email them to me at wdm@trcable.tv it would be greatly appreciated. The serial number is 64600310-3192 and the model number is 574-60030. I don’t feel very comfortable proceeding any further without at least some of the printed materials. As stated before any help would be greatly appreciated. Thanks, Bill M
June 17, 2020 at 7:19 pm #206004June 19, 2020 at 9:53 am #206129Thanks for the reply buccaneer. The diagrams you posted will be a great help and a good start. I did get the flywheel off and there is some surface rust on the inside of the flywheel and stator. What would be a good way to remove the rust? I wouldn’t want to damage these parts by using anything too harsh.
June 19, 2020 at 10:32 am #206131A little rust is normal and won’t affect the magneto’s function. If you want you can clean it up a little with a wire brush and/or a bit of medium grit sandpaper. Just don’t get the grit and debris near the points. Clean the points up with 400-600 grit wet/dry sandpaper ….give them a squirt with brake cleaner and then run a piece of paper (like a grocery bag or business card) through them for the final clean. Put the flywheel back on and test spark. You will probably be fine.
I do see that discount marine parts offers a carb-kit for your engine….so if after having a look at it you can opt for that if you see the need. Often just a cleaning and inspection is all that is needed; try and save the gaskets as you take it apart. The kits are $$$$$
Maybe others here will advise you re: the lower unit grease or oil. Check that before running.
Good luck!
June 19, 2020 at 10:43 am #206132Interesting chat about your carburetor here:
June 19, 2020 at 12:19 pm #206135June 20, 2020 at 10:00 am #206184Thanks again for the information on rust removal and a special thanks to Seakaye 12 for the carb pictures. They will be very helpful! When I first heard of this motor I posted pictures and received comments that this type won a “slow trolling” contest. I can’t wait to get this motor on the lake and see how slow I can go.
