Home › Forum › Ask A Member › Sears 12HP
  • #6817
    ko4nrbs
      I have inherited a Sears 12HP outboard Model 571-59271 Serial Number 59271.1017. I have learned that it was built by Westbend in 1965 but can’t find any parts for it. It is in great condition but needs a water pump impeller. Any idea where I could find one?
      Thank you,
      Bill
      #56558
      kevinrude
        These guys might be able to help you out. I’ve never used them before, so I can’t vouch for them:
        http://elginoutboard.com/
        Interestingly, this website (that I have ordered from before and can vouch for, says your motor is a 1960 7.5HP). They could have parts too:
        http://discount-marine-parts.com/ob_elg … model.html
        And then this site looks like it has some good general info:
        http://www.oddjobmotors.com/west-bend.htm
        Good luck to ya!!
        #56560
        CHUCK
          Here’s a PDF with a somewhat abbreviated service manual for the West Bend 12.
          http://www.fiberglassics.com/library/im … ual002.pdf
          #56572
          ko4nrbs
            Thanks guys!!
            Looks like I need to find someone who reproduces impellers? Anyone out there that does it?
            Bill
            #56580
            CHUCK
              You might need to go that route. You submit your old "core" and the new vanes are added. Before you go that route you can check with member chrysleroutboarddude to see if any of the available Mercury/Force/Chrysler impellers will work….or if he knows of another similar impeller from some other application that would work with perhaps some minor modifications.
              I just installed a $15.00 OMC impeller in a Chrysler; the genuine Chrysler impeller (from Mercury) costs $125.00! So; there are sometimes solutions that are not readily apparent.
              Here are a couple of sources for "made to order" impellers:
              Bob Long (Flying Scott)
              http://home.earthlink.net/~flyingscott/index.html
              Brian Wilcox:
              Baron0418@att.net. Please note the B must be a capital Or 810-794-7685 before 8 pm est please
              #56583
              b-dittmar
                I am about 99% sure this impeller will work in the 12hp West Bend
                http://www.marineengine.com/newparts/pa … -00194.htm
                #56601
                ko4nrbs
                  quote B-Dittmar:
                  Thank you!! I’ll give it a try.
                  Bill
                  #56742
                  amuller
                    If that motor is a 12 hp West Bend from the 60s there is a Sierra impeller that will fit. Most likely the one listed above. Chrysler bought West Bend and continued many similar motors. Take a close look at the starter pinion and be gentle with it. The are a weakness of these motors and not always readily available.
