Home › Forum › Ask A Member › seals and gaskets
  • #5245
    cwalker
      Lower unit seals and Gaskets for a 12hp Scott mac. Where is the best place to buy these parts? Thanks. Charles
      #43945
      wedgie
        Good to see you back on the boards Charles !
        http://www.laingsoutboards.com/scottmccullochparts.html
        OOPS, Sorry . I see the lu seal kit is NLA. 😳
        #44049
        cwalker
          It’s good to be back, somebody out there must know of a source for these scotts.
          #44053
          retiredoz
            Looking at the parts diagram, I sorta understand. Aside from the prop shaft seal, I only see grease plug seals and maybe a shift fork extension seal.
            Not a whole lot there…
            #44054
            cwalker
              What about a seal for the driveshaft?
              #44082
              retiredoz
                I can find old Sierra numbers, 18-2108 for the prop shaft seal and -2109 for the upper drive shaft seal…But it seems both of those numbers are used for something else these days. Still trying to find dimensions for those seals..
