Home › Forum › Ask A Member › Sealing copper head gasket
  • #5308
    GARY
      Replacing head gasket on PO.Does it need to be sealed?Is OMC gasket sealer OK for this?
      #44402
      Leon
        I don’t believe any head gasket gets sealer. I could be wrong, but I don’t believe those do.
        #44403
        Randy in Tampa
          is it a new gasket or an old gasket? copper gaskets usually just need to be tightened down, sometimes they need to be retightened a number of times…. 😉
          #44408
          GARY
            New gasket.I asked because I’m replacing a head and both it and the old one had some old sealer on them.Thanks for the answers,I’ll follow your advice.
            #44423
            fisherman6
              I have never used a sealer on any head gasket on any engine I have ever worked on. This includes those that others have seen fit to use a sealer on before me. Right or wrong, that’s how I have always done it.
              -Ben
              OldJohnnyRude on YouTube
              #44458
                Get all surfaces spotless.
                #44496
                reivertom
                  If everything is clean, flat, and straight you shouldn’t need anything but a gasket.
