Home › Forum › Ask A Member › Seal Assembly Kit 376311 for TN-27
  • #1538
    archangel
      Forgive my ignorance, but what was the intended purpose of the carbon seal kit for the TN-27 & TN-28? My TN-27 appears to not be fitted with those parts, is that any case for concern?
      #16426
        It is an improved seal for the crankshaft. Keeps water out of the crankcase.
        #16428
        archangel
          Thanks, Frank. I figured it would be you who had a quick answer to that one. If it isn’t there should I be concerned? I’m not planning on this being a heavy use motor, just one of the collection that will be run from time to time.
          #16465
            Most of those motors have defective or missing seals. Good old dependable Johnsons, they run anyway. Probably wear out faster though. But salt water is death if it gets into the crankcase.
            #16477
              Here, this might help you out a bit.
              #16482
              archangel
                Thanks to you both, Frank and Mumbles.
                #16490
                bkrsdoz
                  Ken Hall in CT has the carbon seals in stock.
