Home › Forum › Ask A Member › Seaking 5hp impeller replacement.
- This topic has 35 replies, 7 voices, and was last updated 6 years, 7 months ago by
AnotherSteve.
March 26, 2020 at 2:31 pm #198466
Hello,
I’m the proud owner of a Seaking 5hp. which I believe to be a 1964 or 65 vintage.
Model GG18801A
SN 36X882526This mighty motor doesn’t seem to be pumping any water so since the intake port looks
clear I figured I’d change the impeller. I believe on this motor the impeller is on the drive shaft
as opposed to being behind the prop. I’ve read that the power head must be removed to do this as
the drive shaft needs to be disconnected there so the lower unit can be dropped.Is this so?
Thanks,
Another SteveAh to be young and foolish again instead of old and still foolish.
March 26, 2020 at 3:27 pm #198470easy way to tell if it is on the prop shaft is if it is a shift motor it must be on the driveshaft….
March 26, 2020 at 3:47 pm #198478The powerhead needs to be removed so the shift linkage can be undone. The driveshaft will slide right out of the crankshaft .
March 26, 2020 at 3:51 pm #198479Your motor is a 1963
March 26, 2020 at 4:02 pm #198480Per reference source,,,GG18801A was 1963 Gale Division of OMC
5 hp Gale Model 5D22B. Impeller is in leg/tower
The more difficult it is to access impeller, the less likely that it has been
checked or replaced. You are wise to put it at top of to do list.
From what I can tell by looking at after market manual your Sea King
is serviced about the same as other OMC 5hp of early 1960s.
LouisMarch 26, 2020 at 4:17 pm #198483frankr : Thanks. I was close.
dave-benard: It is indeed a shiftable model.
Mumbles: When doing research on pulling the power head I found reference to “seven screws”
that would need to be removed. If the screw heads are located on the outside of the motor
I’ve only been able to find four of them. Is there a handy dandy diagram that shows these screws?Thanks
March 26, 2020 at 4:20 pm #198484Thanks green-thumbs.
Other than the impeller and filling the gearbox it’s ready to go.Ah to be young and foolish again instead of old and still foolish.
March 26, 2020 at 5:18 pm #198493March 26, 2020 at 5:22 pm #198500Thanks Mumbles!
March 26, 2020 at 5:37 pm #198505Being a 1963, did the Sea King 5s have a thermostat like most of the Johnson/Evinrudes of that era?? If so, it won’t pump ,much for water until it warms up, and even then you may only see a spray discharging. Look and see if there is a thermostat housed on the cylinder head’
Dave -
