Home › Forum › Ask A Member › seafoam and engine ping
  • #2370
      any of you folks know if "seafoam" .. the miracle product for our oldies is any good to cure engine ping in a car.
      my kia Sorento 2011 is rattling under r load when accelerating πŸ™
      #22755
        My personal un-knowledgeable opinion is that it won’t work. I’d rather believe you have some fault in the computerized fuel injection system. Possibly a bad sensor somewhere.
        #22763
          quote FrankR:
          Not personally familiar with you vehicle but I suspect your in need
          of a knock sensor. This sensor detects pre-ignition and retards the
          timing accordingly. Best to take it to where they have experience
          with your brand and have the proper test equipment. Allowing this
          to continue can be way more expensive and inconvenient than what
          taking it in now and leaving it for a day will be.
          #22764
            I should find out this a.m. ….now that my 5 year warranty has expired I am certain my dealer will find the expensive problem reported to them before my warranty finished 3 months ago
            #22775
              well after 1.5 years of rattling…. 2 inspections…. this am they found loose nuts on a baffle around the exhaust manifold…
              no seafoam needed
              #22779
                Well, I reckon the end result was good news. I’ve been hearing a rattle in my zero-turn mower for awhile. Yesterday I found the cause–engine fell off. Sheared off all 4 mounting bolts.
                #22781
                  quote FrankR:
                  Ha ha! Come on Frank, you know better than that. No maintenance?
                  #22791
                    frank.. I had the same on my tractor (White/MTD) had only one bolt left in place !!
