Home › Forum › Ask A Member › Sea King Year ID/photo test
  • #5575
    PugetSoundBoater
      Going to be checking this CL listed motor out soon . Any idea what year it is and where the Motor ID tag is located,seller could’t find the tag.Now comes the fun part attempting to attach the photo 😀 Jim
      Robbie Robertson
      #46524
      PugetSoundBoater
        Holy Cow – the photo attached !
        Mumbles<thanks for you guidance! Jim
        Robbie Robertson
        #46526
          Steer it to one side and look for the tag between the stern brackets. Reverse the two numbers preceding the "X" and you get the year. Reverse 16X and you get 61X—a 1961.
          #46527
          PugetSoundBoater
            quote FrankR:
            Steer it to one side and look for the tag between the stern brackets. Reverse the two numbers preceding the “X” and you get the year. Reverse 16X and you get 61X—a 1961.
            Thanks Frank- that was a colorful photo of your Gale 3 hp variants 3 hp you sent me . you should post it here! Thanks for the decoding info. Jim
            Robbie Robertson
            #46531
            JOHN D.
              I sold one last year that looks exacty like that. The new owner ran it without oil and out of the water. Just sayin’. Great runner when I had it.
              #46534
              CHUCK
                Wow…lots of Sea Kings up your way. $50.00 for a 35 HP that "needs a tune-up". Not bad; I’d look at it if I was closer….
                #46536
                PugetSoundBoater
                  quote John C:
                  Hope that isn’t the one i’m looking at tomorrow! FrankR said to look for blistered paint on the cylinder, indicating a overheat commonly from a gear case leak into the water pump.
                  Robbie Robertson
                  #46549
                  JOHN D.
                    The one i had was a 1960. You should be good to go. Something to check is the top crankshaft bushing for wear.
                    #46561
                    PugetSoundBoater
                      quote John C:
                      grab the flywheel and move back and forth in all directions to check for movement.thanks
                      Robbie Robertson
                      #49599
                      chip-chester
                        The one on its side, under the tarp matches my ’58. Unrestored survivor.
                        Chip
