Home › Forum › Ask A Member › Sea King Midget powerhead rebuild.
  • #5067
    keplerfan
      O.K. …So, I’ve never rebuilt a powerhead before and I would like to rebuild a midget from ’46. Do I just hone the cylinders and get new rings or what? What is the basic procedure for rebuilding a powerhead? Where do I get rings?
      Thanks.
      Neil.
      #42685
      cajuncook1
        I guess the first question would come to mind would be why does the powerhead need to be rebuilt?
        – Low compression?
        – broken rings?
        – out of specs for bore diameter?
        I am certainly not an expert on your little motor, but use caution before deciding to hone and re-ring a motor of that vintage. That little motor does not pop up often.
        I dug up this information that Frank Rob posted regarding the little Evinrude midget.
        quote :
        1939-47 Sea King Midget Single; 1cyl, 1-3/8″ bore x 1-3/8″ stroke, piston displacement 2.0 cu in, 1 hp @ 3750 rpn, 2 blade prop, breaker point gap .020″, Spark plug Champion 6M or J-9 @ .025″ gap, Shear pin 5/32″ x 3/4″ aluminum, weight 13 lbs, oil 1/3 pint SAE 30 non-detergent per gallon (24:1), fuel tank capacity 1-3/4 pints, run time, full tank 1 hr, 30 min to 2 hours, water cooled, rope start.
        #42689
        JOSEPH BRINCAT
          What cajuncook said X2 … also often in these small motors the problem with hard starting and/or poor idle is not the bore and rings but rather poor crankcase compression due to worn crankshaft bearings. Fixing that problem is a job for the machine shop. Lateral movement of the flywheel = worn bearings.
