Home › Forum › Ask A Member › Sea King 12 serial number question
- This topic has 5 replies, 4 voices, and was last updated 1 year, 7 months ago by
PAUL WOOD.
March 17, 2025 at 9:03 am #294697
I just acquired a 12 hp Sea King with a model number GG9016A which I find is a 1955 model. The serial number is confusing me as it is 45X559905. The motor has the internal tank but has been bypassed by a fuel pump system. I know the 45 is the mark for a 1954 model with an internal tank, but it would normally be on the model number. So does the 45X55 mean it was a factory fuel pump modification of a 1954 in 1955 as the stamping on the plate looks like it was done at the factory not added later. Any help would be appreciated.
Paul. Western Reserve Chapter OH
March 17, 2025 at 11:14 am #294703Paul I will try to answer your question. Gale Corporation built SeaKing, Brooklure, Royal, Sea-Bee and a bunch more outboards for a lower price. Good quality motors but a little less cost. My experience is Gale was used to test some components and use up obsolete parts. Fuel pumps were used several years before Johnson/Evinrude started using them. The leg, lower units, the lack of cylinder head continued several years after they were phased out on J&E motors. Some Gale internal components like roller bearings and better seals an easy open cowl came along a few years after J&E got them. Hope this helps.
dale
Get’em wet….Don’t let’em set!
March 18, 2025 at 7:55 am #294725Dale your info was interesting. I have owned several Gale motors but have never seen a serial like this and was wondering if anyone had seen something like this.
Paul
March 19, 2025 at 12:26 am #294734I seem to recall that some mid 50’s Gale 12’s could run on either the internal tank or via a remote tank.
https://www.youtube.com/watch?v=WINv_HVVnfM
(“1954/55 Sea King 12 hp. Model GG9016A Test Tank” — same as your model)
has a video description:
“1954/55 Gale Products Division Sea King 12 hp. With duel fuel supply system. You could use the on- motor fuel tank or it has a connection for the OMC remote fuel tank. I’ve had this motor out on one of my 14 foot boats and reached 22 mph and to me that’s incredible! 70 years old and runs out beautifully”
http://www.omc-boats.org
http://www.aerocraft-boats.orgMarch 19, 2025 at 5:43 pm #294742Paul, I have a 1954 – 1955, Model Number GG-9016A. My Serial Number is 45X559838. Have also a 1957, Model Number GG9016C, Serial 75X672393. The identification comes from a Gale Service Manual, Second Edition. This manual does not list the 1954 and 1955 Sea Kings separately, instead, 1954-55. The Deluxe 12 came out in 1956, have one of those as well. They have very similar styling, no internal tank on top though. In addition, different leg, similar if not the same as the 1955 and later Evinrude/Johnsons. I could go on, many other updates. The 1954 and 1955 Sea King 12’s were known as Deluxe. After 1956, they were referred to in advertisements as the Sea King Standard 12. Wards catalogs can be used to confirm this fact. From 1956 to 1958 the Standard model was only advertised in the Spring sales catalog supplements. Sold for considerably less than the Deluxe. It should have, a lot less features! I do not think any of the 54/55 or later Standards were ever “packaged” with a remote tank from the factory. The large catalogs and the sales supplements sold the tank and fuel pump as an accessory item for the motors. My family owned a new 1958 Standard. I can remember my dad purchasing the tank and watched him install the fuel pump with my uncle. The internal tank is completely disabled after adding the fuel pump. The only way to use the tank, on top of the motor again would be to pull the cover, move the fuel line from the pump back to the internal tank. I should think that most everyone would have eventually purchased the remote tank and pump. I recall, we did not get very far on that internal tank. Plus, spilled gas in the lake trying to fill it up. So, why design a motor with the internal tank? Gale did not want to directly take sales away from the Johnson and Evinrude dealers. The motors offered by Gale would, early on, be sold with fewer features and less horsepower. The midrange engine was a 12, not a 15, the big “gun”, a 22, not a 25. In 54 a popular feature was a remote tank on Johnson and Evinrude, Gale had the 12, less horsepower and no remote tank. When 1956 rolled around, a new Sea King 12 was introduced, now the Deluxe had a smooth top, no gas cap, instead a fancy remote tank was utilized. Plus a sealed hood with new suspension. It did not have easy servicing however, hood would not easily lift off like cousin Evinrude or Johnson. Further, no trolling hold on the throttle. They pulled over with more difficulty as well, no fancy timed recoil either. I hope to have one of my Standard 12s on the water in the next couple years, will bring back some great memories. As a kid, we raced the neighbors boat, a Crestliner, like ours, but with a 1955 Evinrude 15. The 12 was not beat. Would not be the case with a Deluxe 12, they weigh more, probably more than the Evinrude due to the bulky and larger casing. Enjoy your motor!
March 23, 2025 at 5:00 pm #294846Thank all of you for the answers. I suspected it was a deal-tank system as I have had other motors like that. I have put a tee in the fuel pump intake line to put it back in the dual design just on case I might need the ability. I had never seen a serial number with the extra numbers so figured it was a bit unusual and rare. I have run the motor in a test barrel, and it runs very smooth. I have had an earlier Sea King standard model 12 hp before and it was a great running motor plus being very fast. I currently have a 11′ Feather Craft Penguin so it will be interesting what it will do as it runs quick with a 10 hp on it now. Paul
