Home › Forum › Ask A Member › Scott Atwater water pump article
- This topic has 16 replies, 1 voice, and was last updated 2 years ago by
Bryan/Aidan.
January 25, 2019 at 7:53 pm #164665
Reading the latest issue of the magazine which has a great article about SA water pumps. Gary OrlofF mentions that he got great pumping results with a 6 blade impeller. Unfortunately, he does not offer a part number for the impeller. Does anyone know the part number?
I am right in the middle of a restoration of a ’57 SA 7 1/2HP motor. Great timing on the article.
January 25, 2019 at 9:41 pm #164685I was wondering the same thing. I have two 1956 7.5 hp “bailers” to work on some day.
January 26, 2019 at 6:13 am #164704Here is the ’56 parts list.
Not meaning to find fault with Gary’s fine article, but in the interest of “Everybody has their way of doing it”, may I offer a tip? Don’t pull the powerhead, pull the exhaust housing. Remove the lower spring mount (two screws), and the reverse lock bail (couple of E-rings). Now remove the bunch of screws holding the powerhead to the exhaust housing and the whole exhaust housing will drop away. Works on high mounted Bailer pump motors right up to 33-40hp. Easy.
We were a Scott-Atwater service dealer back in “The Day”, so I had the pleasure of doing many of those pumps.
January 26, 2019 at 9:23 am #164811Thanks for the information and tips Frank. I’ve added it to my Scott folder
for future use!Prepare to be boarded!
January 26, 2019 at 11:57 am #164836Thank you Frank. I went to ebay to look for the impeller. The part number listed on the parts breakdown shows a 10 blade impeller on ebay. Is there a different/updated part number? I didn’t find a lot of suppliers for Scotty parts. Do you know if there are suppliers that would have the impellers mentioned in the article?
January 26, 2019 at 2:51 pm #164874I don’t know anything about ten blade impellers for Scott. I suggest club member Bob Long for S/A reproduction impellers.
http://home.earthlink.net/~flyingscott/January 26, 2019 at 3:57 pm #164877Certain Honda six blade impellers will work in the 7.5’s and I do have a few of them here somewhere and if I can find them, I’ll post the Honda P/N.
If you do a search, you might find an old thread here on AAM which discussed using Honda impellers in the S/A motors.
January 26, 2019 at 4:48 pm #164892Thank you for the info. This is great!
January 27, 2019 at 8:26 am #164950Guys,
Gary Orloff here, first of all thank you for your kind comments on my article on Scott Atwater cooling & bailing pumps.
The member I mentioned in the article ( John Hagerman ) got his impeller from Bob Long, Frank noted his Email address in his comment ! Bob’s impeller’s works great in both the cooling and bailing pumps if you actually need the bailer to work ! We didn’t use it in John’s motor and plugged the little hole that feeds water to the bailer as we didn’t feel it was needed for his aluminum boat.
With as much water as these pumps produce I don’t think it is really necessary to plug that hole !One thing I didn’t mention was on starting a SA motor that hasn’t been used for a while, Priming the Pumps. Back in the 2015 April issue of “The Antique Outboarder” I wrote an article titled “What’s that Dimple for ? ”
Scott Atwater had a modification for their engines that was the installation of a flushing device if you ran the motor in salt water, but it was also a way to wet the pumps prior to starting them which helped the impellers to draw water up the suction tube. If you have a manual available you should be able to find the information on the flushing device and it’s installation ! If you don’t please feel free to contact me and I will get the information to you.And Bill, stay away from the 10 blade impellers they don’t work ! Mumbles, it would be great if you could find those Honda impellers that can be used in a Scott Atwater and post their part number on this thread !
Thanks again guys
Gary
January 27, 2019 at 8:46 am #164953I found this in my “Scott” notes. No idea if the Honda part number has
been verified as a working substitution for Scott impellers, or what
modifications, if any, would be necessary.
Postby Brian » Tue Mar 07, 2017 9:39 amI ran across this inexpensive, readily available Honda impeller that is supposed to fit the Scott Atwater Bail-A-Matic 7.5hp. Just passing along the info. Curious to find out if it works:
Honda 4-stroke 8hp 9.9hp BF8D BF9.9D
19210-ZW9-013
Number of Blades: 6
Plastic Hub
Height: 14.77mm
External Impeller Overall Diameter: 45.04mm
Internal Shaft Insert Diameter: 13.35mm
==========================================Prepare to be boarded!
