Home › Forum › Ask A Member › Scott Atwater 5hp 1952
  • #285893
    jamesdavisiii
      I got a basket case 5hp Scott Atwater got most back together but the hood brackets and fuel pump mount, anyone got a good picture I can go by? This is the gold and greenish model, came from one of the Atwaters so he said,  Nephew. nice condition but in boxes.
      #285896
        A model number might help someone find what you need.
          Do you mean the 1953 model?
          1953-Specifications
          #285998
          jamesdavisiii
            I’ll get the number off it, might be newer. Those look like a Firstone I have, I think the hood is different, could be wrong. haven’t got the far yet to know exactly what it looks like just the gold and green colors. Jim
            #286019
              Many Scotts & Firestones shared hoods only the trim pieces were different. I still have a 1947 Firestone 10hp & my first motor was a 54 Firestone 7.5hp. Take your time & please ask for any advice here. One thing I learned from Frank is the idle jrt on the carb controls air flow not fuel. My 7.5 ran lean until advised.Those pics bring back good memries!!i
              #286277
              jamesdavisiii
                Took me a while to find it, this is in pieces. 37557463
                #286278
                jamesdavisiii
                  Found the model number 37557463. I rebuilt the power head a couple years ago. all new seals rings. was set up from setting. so the parts got stored for a while. cancer problem, that’s over for now.  If I can get a picture of brackets that attached to power head make it easier, mags in nice shape, pumps don’t look bad but may switch impellers with Mercury ones.
                  #286279
                  nabmd
                    Model # 3755 is a 1955, 5 HP, Twin cylinder engine as per the Scott-Atwater info I have. he #3 indicates it is a Scott-Atwater, #7 indicates 5HP, #55 reversed, indicates year, which obviously makes no difference in this case. I have the 3735 model, 1953
                    #286324
                      Not sure what you mean by hood mount brackets but here’s a pic of the fuel pump on my ’56 gold top 7.5 horse motor. I’m not sure  if it’s the same as yours or not though.
                      Also, here’s an interesting read about the Scotts/Firestones over at Oddjobs:
                      https://www.oddjobmotors.net/scottatwater.htm
                      DSC01482
                      DSC01478
                      DSC01604
                      #286343
                        Mice mtr Jim.My 53 Firestones had a flat fuel pump & no glass bowl to clean. Yours has that “reversed” gear set up too, one drive gear & two pinions, right?
