Home › Forum › Ask A Member › Scott Atwater 1953 Straight Lower
  • #278602
    Mark Hlavin
      Hello, new to this forum. I have a 1953 Scott Atwater 10HP Gold Pennant. Can anyone tell me where the water intake is located and I’d the water discharge is the series of holes on the back center of the lower unit. Many thanks, Mark
      #278611
        Part number 3825-5700
        water-intake
        #278617
          Nice motor!
          I have a 53 Firestoone, same motor. I ran real fast with mine, noisey but very much fun. Welcome to AOMCI!!
          #279120
          Mark Hlavin
            Thank you!!!
            #279125
            Mark Hlavin
              Perfect! Thanks…is the discharge the holes in the back of the lower unit? Just got it started…ran it for 30 seconds or so but did not see any discharge water out if the holes. Shut it down but need clarification before trying to change the impeller. Any thoughts?
              Mark
              #279292
              Mark Hlavin
                Thanks Frank! Do you know if the water discharge is out of the holes on the back edge of the lower unit? Got it started but saw no water discharge and shut it down after 30 seconds or so. Hoping it’s not the impeller but very well might have to change it out. Thanks, Mark
                #279299
                Tom
                  It’s likely the impeller.  A few tips:
                  Be careful taking this all apart.  I’ve done a few of them in the past few years and the driveshaft is often stuck in the crank.  Don’t even think about using a hammer on the anti-cav plate below the pump housing, it is very fragile.  Work from the top end by loosening the powerhead and rocking it to break the driveshaft free of the crank.  I believe there are folks that rebuild these impellers, so if you have the core, you may be able to get a replacement.  I used a very inexpensive Honda impeller, but a few modifications were necessary.  Its use required making sure that the original impeller insert is flat on the bottom, not deformed from corrosion underneath and trimming down the height of the impeller insert.  Then a strip of brass was formed and soldered to reduce the ID of the insert.  The motors have pumped well with these mods, but once done the motor cannot be returned to stock without replacing the pump insert.  On other Scotts, I’ve used the Honda insert, modified, but I’ve never tried that with the Pennant (straight leg) motors.  As noted, these motors are pretty loud.  I’m considering some sound deadening liner on the covers; I think most of the noise is from covers rattling.
                  Best of luck, hope to hear about one more on the water.
                  T
                  #279325
                    Yeah, I think so. It has been years since I ran mine, and then only a time or two. I gave mine away because I couldn’t start it with my worn-out bone-on-bone shoulder.
                    #279666
                    Mark Hlavin
                      Frank,
                      Many thanks, spent some time with it and it now is discharging coolant water!! Appears that no tear will be required but you never know. Appreciate the counsel and guidance!
                      Mark
                      #279667
                      Mark Hlavin
                        Hi Tom,
                        Appreciate the guidance….at present, I was able to get coolant water flow while running the motor. Flow was sporadic but improved as you might expect above idle. Agreed the impeller replacement will be tricky….I like your advise. Thanks for the support !
                        Mark
