Home › Forum › Ask A Member › Scott Atwater 16 hP Fuel pump
  • #279380
    huntleybill
      Are these pumps repairable? I have one that is not pumping fuel. Are there kits available or do I need to retro fit a new one?
      Thank you for your advice.
      Bill
      #279411
      CHUCK
        Very simple pump;  you will need to cut a diaphragm out of bulk material. Fuel Pump Diaphragm material
        Buna-N-Nitrile,    appx .012 thickness
        #279463
        huntleybill
          Do you have a link to that material? I looked on Amazon and ebay, but the thinnest I can find is 1/16″ (.062)
          Is this the stuff?
          https://www.amazon.com/Buna-N-Sheet-Black-Length-Durometer/dp/B006IIWX12/ref=sr_1_19?crid=1CUT0DV2GVYUH&keywords=Buna-N-Nitrile%2C+appx+.012+thickness&qid=1692557047&sprefix=buna-n-nitrile%2C+appx+.012+thickness%2Caps%2C123&sr=8-19
          #279466
            I’ve ordered from this person a couple of times over the years.
            http://www.pfs-ware.com/Parts/OllieParts.htm
              Sheets | McMaster-Carr
              High-Strength Oil-Resistant Buna-N Rubber Sheets and Strips
              These sheets and strips offer better shock-absorbing qualities and longer life than standard Oil-Resistant Buna-N. Buna-N is also known as nitrile, NBR, and acrylonitrile butadiene. It resists fuel oil, hydraulic oil, ethylene glycol, and grease.
              3D CAD models availableFor technical drawings and 3-D models, click on a part number.
              Sheets
              • Color: Black
              • Temperature Range: -40° to 212° F
              • Tensile Strength: 1,500 psi
              • For Use Outdoors: No
              12″ × 12″
              12″ × 24″
              Thick. Thick. Tolerance Choose a Durometer Each Each
              1/64“ -0.005″ to +0.005″ 40A (Medium Soft), 50A (Medium) 86715K259 $6.12 $9.54
              #279476
              CHUCK
                Ideally the material should be reinforced with a mesh.For whatever reason it seems rather difficult to source.  A year or two ago I ended up purchasing from an e-bay vendor in the UK.  Couldn’t find what I wanted anywhere else.  It’s still available from them:
                https://www.ebay.com/itm/313421676905?hash=item48f9634169:g:QhsAAOSwqTVgLBqM
                I’m not sure what’s going on with the pfs-ware link that Buccaneer posted.  I sent them a check earlier this year and my letter was returned as an invalid address.
