Home › Forum › Ask A Member › Scott Atwater 1-30
  • #188295
    Matthew Pieklik
      Hi All, Just picked up a Scott Atwater 1-30 16 HP at auction for $50.00. I even got the controls too. My serial number is 51901988. So I think that makes it a 1951 . Anyone know where I can get the proper parts / service manual? Thanks , Matt.
      #188312
        Here are the parts
        Specifications
        Skirts
        Crankcase
        Gaskets
        #188318
          More
          Lower-Unit
          Lower-Unit-Parts-List
          Magneto
          Propeller
          • This reply was modified 6 years, 11 months ago by frankr.
          #188325
            More. Sorry, I’ll have to hunt for the carburetor. I have it somewhere</strong
            Stowaway-Gas-Tank
            #188328
              Carburetor
              MD-43A-Carburetor
              #188379
              Matthew Pieklik
                Thank you thank you thank you! ( I feel like Gomer) This really helps a lot. Took the covers off and found NGK A-6 plugs. Had spark on #1 cylinder. Pulled the fly wheel. Coils are toast. Originals. So now , I”m on the hunt for the usual suspects. The motor looks like it’s from outer space. So cool. Can’t wait to run it on the lake next year. Again, Thanks for the help!
                #188408
                David Bartlett
                  That is a cool looking motor!
                  David Bartlett
                  #188496
                  Michael Brown
                    I have one of those locked up though. I may have a service manual on cd. I will have to check. I think these are cool motors also. They are built like a tank. With the controls is special. If I can figure a way to contact you by direct email I might can get you to a manual or a link to dropbox might work better.
                    Regards
                    Mike B.
                    #188514
                    CHUCK
                      The driveshaft on those is very unusual; various pieces connected together. When (if) you get it apart…..I’d like it if you could post some pictures of the driveshaft?
                      Thanks, Chuck
