Home › Forum › Ask A Member › S 45 mag
- This topic has 6 replies, 6 voices, and was last updated 11 years, 5 months ago by
George Emmanuel.
June 10, 2015 at 3:00 am #1730
I am in the process of replacing the ignition wires in a S 45 and found that all the (tar) was removed from the coil cavity. what was used and where can I get some or something to replace it with? thanks Gary
June 10, 2015 at 4:13 am #17892I am thinking either roofing tar or hot melt glue. I haven’t done this yet but for a future project that will need the same attention.
June 10, 2015 at 4:53 am #17893There is a product Permatex which I"ve used. Read the instruction as I believe there are several types….Brian
June 10, 2015 at 10:42 am #17897I’ve read on here you can use liquid tape. You add a little bit at a time so it can dry thoroughly. I used it when I ran short of the tar stuff.
June 10, 2015 at 12:12 pm #17900A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
This reply was modified 7 years, 12 months ago by
Tubs.
Tubs.
June 10, 2015 at 1:23 pm #17905Save and label the tar in a baby jar for the future collector. 🙂
June 10, 2015 at 8:47 pm #17937I wouldn’t use anything in that cavity—there’s no reason to. The original setup had a fine wire spring going from the coil tabs to the plug wire and it was encased in a thin glass tube. The tar kept things aligned and tight in there and isolated any moisture because there was not a soldered connection to hold the plug wire spring in place. On my engines I completely clean out the tar and I make small inserts out of delrin that go in the plug wire opening in the mag plate that have a tiny hole in the end and a "collar" on the end of the insert that prevents it from going in too far. It is designed such that the bakelite insulator, when screwed in, pushes the insert towards the coil tab. On the insert where the tiny hole is, the stripped plug wire where it protrudes, is cut and soldered in a ball shape so that when you screw the insulator in it pushes that solder ball into the coil’s tab. The wire cannot be pulled out due to the solder, and rotating the wire won’t damage the coil’s tab. It is clean and works well.
