Home › Forum › Ask A Member › Running an engine not off the tank?
  • #4311
    wyo307
      Hi guys I was wondering if anyone has come up with a way to run one of their motors that has a built in tank like most do without having the tank on the motor? I am specifically wondering about a zephyr. Mine keeps sucking crap through the tank and plugging up the carb even though I have tried cleaning the tank out a few times. I was wonderin if there was some way to run a line from the fuel line on the engine to a water bottle or something full of fuel I can hang above the engine. This would simply be for testing purposes to make sure I don’t have bigger issues. I still haven’t heard this old girl come to life so I was thinking it would be one way to bypass one of the known problems I have. Has anyone done something like this just to test your motor for a minute?
      #36796
        Sure, used to do it all the time. I used an old lawn mower tank with a hose from the petcock.
        #36817
        SCOTT BOGUE
          I made a one pint (about) fuel tank out of a 14" length of 2" rigid PVC pipe, a quarter turn fuel valve, and a length of hose. It has an eyebolt in the screw cap in the upper end so I can hang it. Very safe and simple. Gas will not harm PVC. It also works fine with remote tank motors and with motorcycles, which is why I made it.
          #36849
            #36856
            wyo307
              How did you get it to seal up at the bottom of the can?
              #36859
                #36871
                Doug Wilson
                  get a plastic small engine fuel tank and put an inline valve on the line so you can shut it off
                  Doug
                  turned off?
                  #36911
                  mike-stroz
                    A Tecumseh plastic tank works really well and they’re cheap and easy to come by.
                    #36922
                    Leon
                      Yep. Exactly what I would do.
