Home › Forum › Ask A Member › Ruddertwin Rudder Conection Question
  • #328060
    Blake Monroe
      I am in the process of restoring a rudder twin and noticed that the bottom of the rudder is held place bya pivot pin with a brass GGG pin securing it in place. I think these are called drift pins if that’s what it is and assume that I could knock it out with a drift punch. But I don’t want to screw it up if I’m wrong. Does anyone know how to get that brass pin out? so far does not wanna budge.
      #328065
        I’d hacksaw if off close to the shaft, then try punching it out.
        Of course, some heat and PB Blaster would help.
          You’re not wrong. That is someone’s repair. If you decide to reuse it I think a cotter pin or a hair pin retainer clip might be a better choice. This is what came in there originally.
          RT
          #328076
          Blake Monroe
            Thank you Tubs and Buccaneers for the prompt reply! I will definitely follow your advice!
            #328077
            Blake Monroe
              I also need to replace the cylinder head gaskets after freeing up the pistons and rings. What gasket material and thicknessdo you recommend?
