Home › Forum › Ask A Member › Rudder twin ID plate questions
- This topic has 5 replies, 4 voices, and was last updated 4 weeks, 1 day ago by
Blake Monroe.
October 7, 2026 at 9:29 pm #329645
I have an Elto Rudder Twin that does not have a ID played on it. I thought this unusual till I’ve noticed two or three other units for sale without the ID plate on those as well. I also noticed one that had a black background instead of the blue background traditional alto coloring. Can anyone help me explain these situations? I’m a newbie to this model.
October 8, 2026 at 2:43 am #329653The ID plate was installed on each and every motor ever built, so if they’re missing, its because they’ve been purposely removed for whatever reason.
WRT the background colour, the earlier Elto’s had a black background. Later it was changed to a blue background, I think in 1924.
Hope this helps,
October 8, 2026 at 7:47 am #329666
You should be able to see the holes from the fasteners where the tag was attached.
October 8, 2026 at 9:45 am #329673I believe you will not find any holes, as the plates were soldered on. Apparently some plates not too securely soldered ,thus the missing ID plates.
October 8, 2026 at 6:06 pm #329725
I haven’t had a lot of these but the ones I’m familiar with did have fasteners holding them on. A couple have fallen out on this one.
October 9, 2026 at 11:07 am #329768Thanks Everyone for the helpful information! My motor does have the holes for the ID if there used to be one on there. I just thought curious as to why I’ve seen so many missing as well as the colors. You guys are the best!
