Home › Forum › Ask A Member › Rotor Fit – ’49 Sea King 94GG9014A
- This topic has 8 replies, 6 voices, and was last updated 3 years, 2 months ago by
HARRY D. NICHOLSON.
September 5, 2023 at 7:53 pm #280225
So, I did a really dumb thing. At least I think I did.
I ordered a rotor from ebay, $$$ OUCH
Unless these things are supposed to fit loose and swell as they get used, I think I got took. Of course I didn’t notice “no returns” when I made the purchase.
Anyway, can anyone confirm that the rotor (as new) is supposed to fit snugly into the housing?
Pics attached.
New One In Housing
Original In Housing
John Gragg
RIverside, CAJust starting in the hobby, please be patient.
48 Sea King 5hp GG9014A. Sold
49 Sea King 5hp GG9014A
48 Johnson TD20. Sold
49 Johnson TD20. Sold
54 Johnson QD15. Sold
55 Johnson CD12. Sold
57 Johnson RJE-19M
57 Johnson RDE-19September 5, 2023 at 8:53 pm #280230I think your new one is okay. The eccentric on the prop shaft wobbles the impeller
around like a hula hoop, causing it to squeeze water toward the discharge.Your old impeller is so swelled up, there’s no room to have any “wobble” action,
and hence, not pump.Prepare to be boarded!
September 5, 2023 at 9:10 pm #280231John – I concur with Buc. Take a look again at the picture I sent you last night showing the new wobbler I put in a Sea King.
"Every time you remove a broken or seized bolt an angel gets his wings."1 user thanked author for this post.
September 5, 2023 at 9:44 pm #280238Thanks, I have read the term ‘wobbler’ on the site and although I wasn’t certain, I thought the term meant rotor. So it makes sense to me now, I appreciate the information.
Best Regards,
John Gragg
57 Johnson RJE-19M
57 Johnson RDE-19September 5, 2023 at 9:57 pm #280239.
September 6, 2023 at 12:06 am #280245Thx Bob, I looked back at that pic and sure enough! It didn’t strike me then, but now I see it.
Thx again
John Gragg
57 Johnson RJE-19M
57 Johnson RDE-19September 7, 2023 at 8:58 am #280296John, I wouldn’t throw away the old one. Maybe sand down the outside diameter to match the new one and save it for a spare, or your next project. I’d use a belt sander to ensure all side edges are nice and square. maybe could have done that and saved $$$. These things are not rocket science. The “tail” on your old one still looks unworn, often that part gets worn and loose in its slot, the “tail” actually seals the input side of the “wobble” from the output side.
September 7, 2023 at 2:16 pm #280304Good idea Joe! I’ve already got my eye on a couple of other motors so saving the $$ is gonna be important.
Best Regards
John Gragg
57 Johnson RJE-19M
57 Johnson RDE-19September 8, 2023 at 10:48 pm #280369When they swell up, they are also softer and too loose fitting on the cam to function. Sanding won’t work unless the cam fit is also repaired.
