Home › Forum › Ask A Member › Resealing an old cork carburetor float
- This topic has 23 replies, 9 voices, and was last updated 3 years, 9 months ago by
JOSEPH BRINCAT.
January 30, 2023 at 11:59 am #272089
Need to reseal an old cork carburetor float.
January 30, 2023 at 12:13 pm #272090Trying to get my 1936 Johnson model 100 with a model J carburetor running again. After carefully cleaning all of the carburetor parts, I am now ready to reassemble but first I would like to reseal the cork float real good prior to assembly. Any tips or suggestions and sources for a product that will reseal the cork floats and not break down with today’s fuels and lubricants? Thank you for the opportunity to ask questions and interact with others of like interests.
January 30, 2023 at 12:30 pm #272091sanding cleaning then fuel proof airplane dope for hobbyst is the usual remedy it seems
I have used “gel type” and lquid crazy glue* with small brush..it seemed to work but I have not openned up a carb fixed this way. Did crazy glue hold up.. hard to say
*KEEP VAPORS AWAY FROM YOUR EYES AND LUNGS….BE WARNED !!!
butyrate is also used in clear finger nail polish which you could try but read the fine print on the bottle
you always try to shape a new one out of cork then seal it
This reply was modified 3 years, 9 months ago by
JACQUES.
January 30, 2023 at 12:33 pm #272092I use fuel proof model airplane dope.
January 30, 2023 at 12:44 pm #272095Thank you crosbyman, I will look into that.
January 30, 2023 at 12:46 pm #272096Thank you Steve, I will look for that product.
January 30, 2023 at 12:46 pm #272097If you use ethanol free gas,you can just sand it lightly and add a coat of shellac.
January 30, 2023 at 12:49 pm #272098Thank you Stanley, that will be hard to do that in my area…
January 30, 2023 at 1:37 pm #272104“Tubs”AKA “The Boat House”,Is doing a long term experiment on whether cork floats even need to be coated.The assumption has been that the coating was necessary to prevent absorption of fuel.His experiment suggests it is not.
January 30, 2023 at 8:03 pm #272115 -
