Home › Forum › Ask A Member › replacement coils for my Elgin outboard
  • #285133
    78bluestreak
      I need to get two new coils for my Elgin outboard motor.  the green coils have a part number of 1000012 on single coil, nothing on the other coil.  that green coils from Asia.
      Are these coils available on Ebay, or other marine parts outlets?  The coils number is not returning search results.  the motor is the selectable horsepower 3, 7,12 HP version from Sears.
      thanking you in advance.
      #285139
        This is the magneto from my 1959 12 hp.
        Is this like your mag?
        It may be possible to do a coil swap using OMC
        universal coils. Perhaps someone that’s done
        it on this magneto will chime in.
        DSCN7952
        CHUCK
          The model number of your Elgin would help.  Or the manufacturer.  Or a picture of the engine and mag plate.
          The bad coils on there now are green and from Asia?
          #285147
            Do either of these look familiar?
            wb6902
            wb160521
            #285155
            78bluestreak
              model number is 571.58901 Egin listed as a 12 h.p. although it is a key selectable h.p on the face of the control panel.
              #285156
              78bluestreak
                no my plate is different.  coils are X7500 from parts manual.  stated as WICO, but later in paragraph mentioned as Fairbanks-Morse coils.
                #285157
                78bluestreak
                  the bottom diagram is close than the top.
                  My model is 571.58901 serial number 901 8351
                  Sears Elgin 5-71/2-12 H.P.
                  yes to WICO 7500 coils.
                  #285163
                    571.8901 is listed as a 1955 12hp, made by west bend.  Closest I can come is 1957 12hp west bend, model 160941.  Yep, X7500 coils.
                    wb160941
                    #285165
                      wb160941-1
                      #285167
                        delete
