Home › Forum › Ask A Member › Repairing cracked solder joints in 1922 Elto Light twin tank.
  • #7443
    Monte NZ
      Help needed please, in how to repair leaks in the fuel tank on the above motor.
      After carefully inspecting the tank I have discovered several hairline cracks in the solder joints near the drain bung.
      I believe that these have occurred as a result of the motor being lifted by the tank over the years, rather than by the power heads over the last 95years. Apart from this problem, the tank is in very good condition with hardly any surface rust and only some shallow dents.
      Thanks very much in advance for any help.
      MonteNZ
      #60406
        just solder it.
        #60407
          If I understand you correctly the cracks
          are in the solder and not in the tank itself.
          Clean around the area really well with
          purple power, super clean, bleach white,
          or some other water base dirt and grease
          remover. You want to rinse it really well.
          Probably be a good idea to do this several
          times. Your looking to get rid of all the
          dirt, gas, oil, and paint? Now you can
          re-melt the solder two ways. One way is
          with a heat gun. Blower setting on low and
          not too close you blow the solder out. Your
          looking to get the solder to flow back together.
          You want the tank sitting level as possible
          with the bung pointing straight up so it
          doesn’t fall over and create a new set
          of problems. You can also re-melt the
          solder with a propane torch but don’t put
          the flame directly on the solder join. You
          should be able to get the solider to re-melt
          by just heating the bung staying away from
          the bottom and side seam. With some luck
          and if you have gotten all the crap out
          the solder will just flow back together.
          #60413
          Monte NZ
            Thanks Dave and Tub’s for your replies.
            Yes, the cracks are in the soldered joints Tub’s.Your suggestions make a lot of sense and is the information I was hoping for. There isn’t any paint to worry about , just the nickel plating, so I’m not too sure what happens to that. I guess I will just scrape it off. You didn’t mention using acid flux when doing the soldering, but I would think that would be a must and to just make sure the tank was washed both inside and out thoroughly on completion.
            Thanks very much once again.
            Monte NZ
            #60415
              Shouldn’t need any flux as your only melting the solder
              back together. The tank and the bung are already
              coated with solder. (tined) I don’t know when the
              nickel is applied. Before or after assembly. Either
              way it wont melt so it shouldn’t be a problem.
              #60416
                I wouldn’t use acid type flux, rosin flux maybe a small wipe above the joint just to remove any left-over crud. No bond when contaminated!
                #60439
                Monte NZ
                  Again, thanks Tub’s and Jeff for your additional suggestions……..it all helps…..much appreciated!
                  MonteNZ
                  #60444
                  kees
                    International Member
                    any fuel residues in the tank to worry about ? ……….
                    take care
                    take and………. 😆 leave the cap off for ventilation
                    you never know, better safe then sorry.
                    #60446
                    PugetSoundBoater
                      For safety sakes, i would fill the tank with water while doing the repair. I know this is counterproductive to getting the motor running, but you don’t want that tank blowing up in your face.
                      Robbie Robertson
                      #60448
                      Monte NZ
                        Thanks kees and pugetsoundboater………very good advice!! I can assure you that I won’t be taking any chances on blowing things up. I will be very very sure to clean the tank thoroughly. I have heard of filling a tank full of exhaust fumes prior to using a naked flame is one way of avoiding an explosion.
                        Thanks again.
                        MonteNZ
                        PS I well remember my Dad telling me that you only need a very small amount of vapour in a tank to have an explosion!
