Home › Forum › Ask A Member › removing pin holding 57 evinrude cowl together
  • #259723
    GUY SCHMIDT
      Hello outboarders, I have a 57 evinrude 35hp cowl that has one bad side. I’m perplexed how to separate them without breaking something. I have a picture with a pencil pointing to the solid end of the hinge…..the other end is open……maybe you can take me from here with instructions. Thanks….Guy
      #259728
      jimk
        I was able to drive mine out with a punch.
        #259733
          I marked up your picture.   On my 57 cowl, I grabbed onto the exposed part of the pin with a pair of needle nosed vice grips, then tapped the vice grips with a hammer to drive the pin out the open end of the hinge.   Also include a pic of mine with the pin driven  out.
          Evinrude-cowl-scaled-copy
          01-Cowl-Hinge-Pin-Removed-06.25
          1982 Evinrude 25hp
          #259739
          GUY SCHMIDT
            OK, I think I now will have the confidence to give it a shot without the fear of damaging it….thank you
            #259741
              Forgot to mention there is a small retainer clip on the hinge pin you will need to remove before driving the pin out – you can see the clip on the pin in the picture of my cowl.  The front edge of the pin is knurled to hold it in place and it wouldn’t hurt to apply a little heat to front end of the hinge to expand the metal a bit and allow the pin to come out a little easier.
              1982 Evinrude 25hp
              #259751
              boscovius
                I can confirm this procedure.  Just went through this a while back.  I had to get a pair of needle nose vise grips in order to get any purchase on the pin, but this is how you do it.
                Here’s the thread from my cowl pin adventure.  Also information on the bales, hinge, pin and retaining clip part numbers.
                https://www.aomci.org/forums/topic/1957-big-twin-35-engine-cowling-separation-latch-bale-pin-removal/
                • This reply was modified 4 years, 5 months ago by boscovius.
                #259990
                GUY SCHMIDT
                  SUCCESS!…..yes, I bought a pair of the needle nose vise grips at ACE hardware, heated up the hidden end of the pin housing ( I had previously sprayed some penetrating oil in there )
                  heated it with map gas for about 15 seconds and it popped out with ease after attaching the plyers to the shaft and tapping on it….Thanks again.
