Home › Forum › Ask A Member › Remote control for 1956 Mercury Mark 25E, no key
  • #293695
    SHELL KOTTKAMP
      Greetings, I have a 1950’s Mercury remote control with the wiring harness for a 1956 Mercury Mark 25E but no key for the ignition switch.  Is there a work around for this issue or is a new ignition switch the only solution.  If a new ignition switch is needed does anyone know what the part # is?  thanks in advance.
      #293696
        did you ask a dealer ?   they should have info and could possibly get a key
        see list  for part 25304 ignition key under Mark 25 archive  in  2 stroke carb outboards
        EzPartsWeb
        #293698
        SHELL KOTTKAMP
          Thank you crosbyman for your reply and input.
