Home › Forum › Ask A Member › Recoil Spring needed
  • #6353
    fishingnuts
      Refurbishing a 1957 Evinrude 3 hp, Model 3022. Needing a recoil spring and not finding a part number, to locate the spring. Any information will be greatly appreciated.
      Ed Ortgiesen, Brownsburg, IN. email fishingnuts42@gmail.com
      #53044
        No Problem. That spring is the most common and was used since the late 1930s. Superseded by 307573 when OMC (yes, it was used by Johnson in the ’30s also) computerized there inventory in 1958 . . 😀
        1956
        1962
        #53047
        fishingnuts
          Thank you, Thank you. Found it on iboats.com.
          Thanks again.
          #53056
            It was the first recoil spring Sierra Marine duplicated and is one there largest sellers. . . 😉
