Home › Forum › Ask A Member › Rebuild kf7
Viewing 10 posts - 11 through 20 (of 38 total)
  • #261639
      Yes . and you can use the mark 20 powerhead on the KF 7 tower.
      #261641
      CHUCK WEBSTER
        Use good oil tcw3. I use Mercury 2 cycle oil.
        #261642
        CHUCK WEBSTER
          Jeff, As I mentioned you need a two line pressure tank for a Mark 20 unless you convert it to a fuel pump and single line tank as I mentioned when we spoke.
          #261643
          wedgie
            Mallett
              Hey chuck, got the motor mounted last night getting ready to give it a test.
              Thanks
              #261652
              Mallett
                Thanks for the link, That will help tremendously!
                #261653
                Mallett
                  Wedgie, Thanks the the link, it will hep tremendously!
                  #261654
                  Mallett
                    Ok, so after I got home yesterday, I checked the the prop and it doesn’t spin. I took the small piston cover like chuck show me, the rings sprang back and the piston didn’t look scored, scratched or all nicked up. So I think that my be a good thing.? So that being said, I start with the impeller then take the lower end out see what’s bound up with looseness  up in there?
                    #261673
                    CHUCK WEBSTER
                      good luck, what gas/oil mixture and type of oil are you using?
                      #261684
                      wedgie
                        You are welcome Mallett. Thanks to the Western New York aomci for making the manuals available. If you haven’t already, call Dave. He’s an expert Merc guy.
                        • This reply was modified 4 years, 4 months ago by wedgie.
