Home › Forum › Ask A Member › Reading Capacitor meter
  • #189312
    GARY
      Before I throw them away,I decided to check a bunch of replaced condensers.I first did the usual test with my multimeter.I then tried using my newly purchased capacitor meter.To start I used new,known value condensers.In the 47nf to 47uf mode,I got a fluctuating reading of an average 220.98 pf.In the 47uf to 470 mf mode,the reading was a constant .12uf. Why?Taking into account the difference in value of pf vs.mf vs.uf,I don’t understand why both don’t begin with “12”,which is the rating of the capacitor.
      • This topic was modified 6 years, 10 months ago by GARY.
      #189355
      vintin
        Use the scale that most closely matches what is printed on the capacitor.
        All capacitors have capacitance, inductance and resistance components. I believe what you are seeing is inductance and resistance of the tested capacitor skewing your measuring device’s readings.
        #189365
        GARY
          Thanks Vintin,That makes sense to me.I’d never used one before.Just got this one and of course it came with un-intelligible Chinese to English instructions.
          #189418
          RICHARD A. WHITE
            Sparkfun had this cool little cap reader.. it is a Doit yourself kit you put together..It will only tell the value of the Cap, but if it is unknown cap value this could be helpful.
            https://www.sparkfun.com/products/9485
            classicomctools@gmail.com
