Home › Forum › Ask A Member › Re-use carbon seal on 1962 ten hp?
  • #1014
    beerman57
      Any reason not to re-use the top and bottom crank shaft seals, if they’re in good condition? Use new O-rings though?
      #12689
      chinewalker
        I reuse them. Never had an issue doing so…
        #12692
        jerry-ahrens
          I always use new o rings while in there. Be careful though, the o rings get hard and when you pry them out you can crack the carbon seal carrier. They are expensive.
          #12698
            Yeah I have re used them. Some I have found to look good, only to crumble though after installing them. So inspect well before re using.
