Home › Forum › Ask A Member › Re: 1949 Johnson HD-25 Overhaul: A beginners perspective and guide for the compleat idiot
Viewing 7 posts - 31 through 37 (of 37 total)
  • #18727
    vwbusman66
      Yes, I removed the primer nut and fork. That pin must be removed in order to allow for the top of the carb bowl to come off so I can rebuild the carb and float. The tank is already off along with all of the primer hardware. The pin is a smidgen too long to allow for it to fit through the hole allotted for it.
      James
      #18736
      steveh
        I used a small punch and tapped it out. If I remember correctly, the pin is tapered, so tap on the small end. Then it pulls out easily with a needle-nosed pliers.
        #18740
        legendre
          quote vwbusman66:
          Now it’s my opportunity to learn something..
          Why do you need to drive out that pin to remove the bowl cover? What prevents you from simply unscrewing the mixture needle until it can be withdrawn from the carb body?
          My question seems so obvious, we must have some sort of misunderstanding here..?
          #18757
          vwbusman66
            quote legendre:
            quote vwbusman66:
            Is the needle supposed to unscrew all the way out? I have sat here for about 20 minutes trying to screw it in and out and it does not move at all. I assumed that it did not screw in or out, and was designed to have the pin removed.
            James
            #18763
            steveh
              You do not have to take the pin out. You can simply unscrew the high speed needle. It will unscrew all the way.
              #18779
              legendre
                This is the high-speed mixture needle we’re discussing – it +must+ be free to turn, else you can’t adjust the mixture. It sounds like yours is stuck in place.. might be due to gummy fuel residue or some sort of dissimilar metal corrosion.
                Try a little heat on that part of the carb body, see if you can get it moving.
                #18787
                aquasonic
                  quote SteveH:
                  No need to remove the high speed needle pin! Just back the needle out ‘lefty loosey’.
                  Improvise-Adapt-Overcome
