Home › Forum › Ask A Member › RD17 electric start
  • #268707
    John O’Shea
      Dave, thanks for the response. What is an exhaust relief and am I able to check it’s operation?
      Fleetwin, will do, thanks.
      #268719
        look on the head it is a mechanical setup that opens a valve to relieve the compression whe you use the rewind starter. yours may or may not have one.
        #268720
          No compression relief on the 25-30hp models.
          #268732
            Are you using the electric start to crank for compression test, or just pulling it over with the recoil?  Sometimes, you just can’t pull em over fast enough with the recoil to get accurate compression readings.  Try using the electric starter.
            #268733
              Perhaps your compression gage is messed up as well, you might want to try a different gage before getting too involved.
              #268735
              John O’Shea
                Thanks all for responses. I just bought the engine, compression test was done by a marina for the last owner so I’m not sure how reliable the results are, although I’m familiar with the mechanic and they have a good reputation.
                #268788
                ADAM GIBB
                  Keep in mind that the marina may be used to working on modern engines with higher compression. For the old RD, 90 LBS is OK. I like to see 100-120.
                  #268854
                    OK, so those readings were given by the last tech working on the engine.  It is worth trying again with a different gage, using the electric start.
