Home › Forum › Ask A Member › RBM WIRING DIAGRAM
  • #188284
    joellerich
      I am looking for a wiring diagram for a Evinrude 1914 model B RBM with magneto ignition. e-mail to john.oellerich1525@gmail.com
      thanks
      #188340
      gofastgramps
        I think a few more of us would like to have one, if available.
        #188341
          • This reply was modified 6 years, 11 months ago by Tubs.
          #188405
          jimparrott
            Tubs,
            I have always wanted to try this on my 1916 Evinrude, it’s hard to get started when cold but starts easily and runs good after. Was it common to use the battery for warm up then switch back to straight magneto, or leave the battery hooked up?
            Also can you post how to connect a Buzz coil ignition instead of using the magneto. Was always scared to ruin my already weak magneto by hooking one up wrong.
            Thanks
            Jim
            #188409
            WAYNE
              To use a buzz box you need to disconnect the coil and condenser and only use the points. The battery booster option is a better way to go because it only requires a battery and leaves the magneto intact.
              Wayne
              Upper Canada Chapter
              uccaomci.com
              #188411
                #188437
                jimparrott
                  Wayne and Tubs
                  That answers my questions. Will make a battery and switch assembly for my weak magneto. I also have another Evinrude with a dead magneto and will hook a buzz coil as suggested to the points.
                  Thanks
                  Jim
                  #188443
                  jimparrott
                    Tubs,
                    I forgot to mention, you did a nice job on the switch. Looks like it belongs there.
                    Jim
                    #188462
                    joellerich
                      Thanks to everyone that replied. Just what I needed, plus additional information.
                      Thanks
                      John
                      #188469
                      joellerich
                        Second question about my 1914 RBM. The tank is very rusted on the inside. I have been looking for something that will stop the rust and still be resistant to gasoline. I also found a loose piece of metal inside. It looks like it might have been some kind of baffle. Any help about the rust or loose piece of metal would be appreciated. Auto parts store recommended Permatex Rust Treatment #81773 then prime and paint. Permatex tech support says the rust treatment alone will dissolve in gasoline.
                        Any ideas or suggestions would be appreciated.
                        Thanks
                        John
