Home › Forum › Ask A Member › RBM Reassembly
  • #202572
    slim60
      I tried to adjust the steering on this ’22 and the driveshaft disconnected. Is there an easy way to reassemble (by the numbers)? My back won’t allow me to wrestle with it. Picture shows engine at TDC and reverse works. Thanks in advance, Slim
      103_0310
      103_0311
      • This topic was modified 6 years, 6 months ago by Mumbles.
      #202578
        • This reply was modified 6 years, 6 months ago by Tubs.
        #202645
        slim60
          Thanks Tubs; I’ll give it a shot tomorrow after I talk to my mom. Prop was steering 0 to 60 degrees port. When all is cleaned, loose, and Brasso too it should be fine.Can’t wait to run ‘er again.
          #202741
          slim60
            Well I slipped it together and the prop spins with the flywheel but when it locks into forward the prop is not aligned at 12 o’clock. I can unlock it with the tiller handle but it rotates 360* to the same place and locks. Maybe it’s time to pull the power head and get a closer look at the shift mechanism. Beautiful polishing job, Tubs.
            #202763
              #202846
              slim60
                I replaced the welded parts with good used parts a few years ago. Only shifted while running maybe a dozen times. I’ll look for the old parts and do what I have to do to keep it in forward. Thank you. Slim
                #202847
                  Sent you a PM
                  #203173
                  slim60
                    I see now the collar and slide were modified on the right. Is there a way to remove the pins in the twist knob from the slide (left) so I can use it on the modified one?
                    103_0314
                    103_0318
                    103_0315
                    • This reply was modified 6 years, 5 months ago by slim60.
                    • This reply was modified 6 years, 5 months ago by Mumbles.
                    #203188
                      #203194
                      slim60
                        Thanks Tubs; Maybe a fixture can be made to press it out on a vise, but I can install the tiller handle with or without the FR sleeve. I’m beyond trying to make this one original. It’s just a good runner.
