Home › Forum › Ask A Member › Ranger coil options?
Viewing 4 posts - 21 through 24 (of 24 total)
  • #283925
      Bill, The factory spark plug gap spec is .025 – point gap is .020.
      I don’t know how valid this is but my spark test for these is to
      ground the plug to the motor and spin and the flywheel by hand
      as fast as I can. I won’t get a spark every time because the magnet
      isn’t always in the proper location but if I get a spark occasionally
      my experience is they will run.
      These things can be a bear to get going for the first time, epically
      after they have been apart or motor has been built from parts,
      I suspect this is caused by the lack if a good seal at the rings and/or
      bearings. Start with 5 oz. of oil per gal. Get one of these driver bits
      so you can spin your motor with a drill. Spin the motor with the mag
      lever between 3 & 4 O’clock, moving the mixture screw from O to 1/4
      turn open going back to O from time to time to be sure it isn’t
      getting flooded.
      I couldn’t get this motor to start on the boat.
      Got it started out of the water.
      Back on the boat it didn’t run well. Notice the mag lever position.
      https://youtu.be/53yTD4zf17c?si=99QpB7_l9ZvhV9G4
      After a few days it got better and it ran great on 3 oz of oil per gal
      the rest to the summer.
      https://youtu.be/3BVbHBJSHgk?si=k9ufSuUP26V-9EfK
      I do have one that is worn enough it needs 4 oz. of oil per
      gal to create a good enough seal for it to run.
      A friend has a Ranger that is so worn out it wont run at all
      but its the only one I’ve ever seen that is that bad.
      As a last resort you can pull the cylinder, put some grease on the
      piston and on lower main bearing to make a known good seal. If none
      of this will make it run for just a little bit, other than some mechanical
      issue, its most likely spark and I’m at a loss as to what it might be.
      #283931
        Tom, there is quite a large gap between the coil output terminals and the plate. I can bring it to Framingham. I wish there were specs I could use to test the coil on my Stevens. That would show a jump to ground. I certainly don’t hear it…a gap that large, I would expect to maybe hear that snap….
        #283934
        Tom
          Oh well, worth a shot…
          T
          #283949
            try running it in total darkness
