Home › Forum › Ask A Member › R J8C Vs. J8C
  • #3009
    elgin2
      Is there a difference in these two sparkplugs? Is one a resistor plug? Thanx in advance.
      #27363
        The R stands for resistor while the V means it’s a surface gap plug. The J8C is just a standard plug. I can’t find any listing for a RJ8CV plug but maybe they do make them.
        #27368
        jw-in-dixie
          Isn’t the J8C a shorter version of the J8?
          JW in Dixie
          #27385
          jerry
            Yes…it’s a resistor plug intended for use with static sensitive devices….I wouldn’t use it but might just try it for running if I already had it. I think it might decrease the intensity of the spark similar to using resistance ignition wire.
