Home › Forum › Ask A Member › QD19 Overheat Question – Update
Viewing 8 posts - 61 through 68 (of 68 total)
  • #21977
    beerman57
      SUCCESS!!! To refresh your memory, I drilled a small hole in the water inlet at the top of the midsection to spray water on the starboard side of the mid and shift linkage. I also shot some grease to the shift handle and that may have helped by preventing exhaust from leaking by the slightly wore out bushing. The shift handle stayed pretty cool, the upper mid was pretty hot but didn’t boil the water when I came down from being on plane. Got 22mph with my 3 blade aluminum (10” pitch) prop on the 13′ Feathercraft, not bad for 10 horses.
      #22030
        Where did you get a 10" pitch prop for that small gearcase 10hp?
        I’m glad the cooling bugs are under control now, thanks for letting us know
        #22032
        retiredoz
          Michigan produced AMC263 8 1/2 X10. Listed in the the ’63 cat, gone from the ’68..
          #22033
          beerman57
            I sent a prop to be rehubbed and told them to add as much pitch as possible. Gained 2mph over a stock power prop, the 10” pitch prop has more round blades than the power prop.
            #22035
              Will surely have to look for one of those props! The standard 8" pitch prop is a joke, OMC did make a 9" pitch which I got and tried, but am thinking the 10" pitch would be perfect for my little 12′ Sears.
              #38338
              beerman57
                Here it is, see if it helps. Page 3 gets to where I drilled a hole.
                #38342
                shoestringmariner
                  AWESOME, thanks Beerman!
                  #38355
                  retiredoz
                    Michigan also also offered AJC175, 8X10, 2-blade brass for 9.5, 10-hp ’58 up.
