Home › Forum › Ask A Member › QD16 Simplex pawl starter assembly
  • #8389
    piddler
      Hello
      Anyone have a diagram on this ? Newbie. First post. This one is wearing me out.
      Thanks for any comments or instructions
      #65746
      Steve D
        Here’s that page from the manual.
        piddler
          Thank you very much. How exactly is part 15 placed in the re assembly?
          Thanks again
          #65755
            http://boatinfo.no/lib/johnson/manuals/ … on.html#/0
            book to read
            #65757
            Steve D
              It’s been awhile since I did one but the way that worked for me was:
              1- Fit the spring into #16, the Equalizer Cup
              2- Slide that over the Spindle making sure the spring is around the lip/ridge of the spindle
              3- Slide that whole assembly into the pulley lining up the pin on the spindle with the hole in the starter housing
              4- Rotate the Equalizer cup counter clockwise as close to the pawl as possible to attach the springs
              5- Screw down the spindle
                It is important not to put pressure on the equalizer cup when installing the spindle. This will push the friction spring off the shoulder on the spindle and cause the pulley to bind when the screw is tightened. . . 😉
                #65781
                piddler
                  Are you the greatest or what!!!
                  Thanks a million
                  #65783
                    and of course clean it up spic and span of old grease, then re grease for smooth operation.
