Home › Forum › Ask A Member › QD15 coil – can I use this one?
  • #282239
      tons of  heat shrink tubing with hot glue inside  of them to seal things up
      Wirefy 190 PCS Heat Shrink Tubing Kit – 4:1 Dual Wall Tube – Adhesive Lined – Marine Shrink Tubing – Black, Red : Amazon.ca: Industrial & Scientific
      #282240
      aquasonic
        Here’s an inexpensive kit. Not nearly as deluxe as the one crosbyman posted, but it works fine. Use the smallest diameter that fits over the connector and shrink it with a heat gun on low setting. Keep the gun moving to avoid overheating in any area.
        42 Piece Marine Heat Shrink Tubing (harborfreight.com)
        Improvise-Adapt-Overcome
        #282248
        JOSEPH BRINCAT
          It’s the ground wire, doesn’t really need insulation… maybe just for cosmetics
          #282577
          sutterhome
            heat shrink twice and call it a day…ground is black
            #282648
              Wouldn’t  using shrink require cutting the terminal off and installing a new one?  Liquid tape would be much easier.
              liquid-Tape
              #282656
              aquasonic
                As long as the smallest diameter heat shrink tube that just fits over the terminal is used, the heat shrink tube works great. No need to remove and reinstall the terminal.
                Regarding the liquid electrical tape, that works too. It’s just a matter of preference. Just don’t try using both together. The heat from the heat gun will melt the liquid electrical tape.
